64 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> IMPORTING AUTOCAD pgp FILE
Mon, Apr 11, 2016 at 2:30:33 PM | IMPORTING AUTOCAD pgp FILE
pwoolson
Hi, Can an autocad PGP file be imported into Revit to match keyboard commands?
Tue, Apr 12, 2016 at 9:21:30 AM | IMPORTING AUTOCAD pgp FILE
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Nope. Its kinda different in the way you use it compared to AutoCAD, so its hard to look at it the same way.
You don't use L for lines or O for offset or F for fillet a thousand of times a day. You end up using a far greater range of tools as Revit is a far more complex software.
You can create hotkeys though using the R button - Options - User Interface - Customise Keyboard Shortcuts route but the hotkeys need two buttons pressed and you don't need to press return after hitting the keys.
I use to use hotkeys heaps in DumbCAD but I hardly use them now in Revit.
dimension change when importing AutoCad file
Thu, Oct 16, 2014 at 10:59:01 AM
Error when importing an AutoCAD File
Wed, Oct 31, 2007 at 5:49:58 PM
Linking AutoCAD Site Contour missing 2014
Wed, May 27, 2015 at 7:56:32 AM
importing Autocad files - modelspace & paperspace!
Tue, Jul 17, 2007 at 8:25:49 AM
REINITIALIZE KEYBOARD SHORTCUTS.TXT
Tue, Aug 28, 2007 at 11:01:52 AM
Page generation time: 1.8212
