Forums >> Revit Building >> Technical Support >> AutoCAD drawing with dash line is showing as solid line when imported in Revit
Mon, Apr 11, 2016 at 10:19:08 AM | AutoCAD drawing with dash line is showing as solid line when imported in Revit
aoyalers
How do you fix this?
Mon, Apr 11, 2016 at 11:11:09 AM | AutoCAD drawing with dash line is showing as solid line when imported in Revit
Importing CAD is usually not a good process, linking is better.  And, never import CAD then explode it.
This HELP may be what you need.  http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-8663EDED-03C4-4BDE-9AE7-A35C1DB35AA7
Mon, Apr 11, 2016 at 7:32:22 PM | AutoCAD drawing with dash line is showing as solid line when imported in Revit
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Additionally, after you've linked your file, you can change the line type by expanding the link from visibility graphics which displays the layers. While you can change the lines from here it will not necessarily "stick" if the file is reloaded. Best practice - avoid importing CAD as much as humanly possible. It always creates problems. It's just a matter of degree.
How to make the dash line scale right in project ?
Fri, Jul 9, 2010 at 7:38:32 AM
Imported AutoCAD 2006 title block line thickness
Thu, Sep 7, 2006 at 3:27:44 PM
Hidden line types and export to autocad
Thu, May 4, 2006 at 10:22:40 AM
Family Symbolic lines Subcategory hidden lines uneven dash line
Mon, Mar 10, 2014 at 7:57:49 AM
Contol Line Types and Line Weights of CAD Detials in Revit
Wed, Mar 4, 2009 at 4:54:33 AM
Page generation time: 1.9736
