Forums >> Revit Building >> Technical Support >> Wall Types - floor plan vs. elevations/sections
2 Posts No Rating |
Hi there. I am new to Revit (one month) and am trying to convert my office (and mind) from Autocad to Revit. I am a residential architect nad have been so for 15 plus years.
Here is my question. It has to deal with wall types. When using basic Autocad, I would typically draw my walls in plan at their true width, ie: 2x4= 3 1/2". In section, I would add the thickness of the finishes (gyp board, exterior sheathing, etc...)
I can see how Revit can save so much time when it comes to sections and elevations. But, in plan, it shows all those lines for the materials. Is there a way to turn those off so that I do not see them in plan, but still have them there for sections and details. It really is driving me up the wall. I do not want to plot with them showing on plan, nor dor I want to see them as I am working on the plan.
I hope this is not a stupid question, but my mind is still trying to convert from 2D to 3D thinking.
Thanks in advance...
in plan set your detail level to coarse and it will display only two lines representing the widith of the wall
best regards,
coreed,aia
Post edited on 2006-04-07 14:34:57
2 Posts No Rating |
I've done that, and it does show just the two lines, but the thickness for the exterior walls shows the face of the finish levels. I just want the plan to show the basic core, and not the finishes. Does that make sense?
This is kind've against the thinking of revit, however you could achieve this by using override host layers in your plan view (visibility settings) and making your finish layer a white line, thus rendering it invisible.
HTH.
Floor plan types |
Thu, Nov 13, 2008 at 9:51:18 AM
IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN? |
Tue, Jan 25, 2011 at 1:25:13 PM
3 elevations 1 floor plan |
Tue, May 15, 2007 at 7:13:02 AM
Wall sections cut from elevation... now not seen on plan |
Fri, Mar 9, 2012 at 11:05:13 AM
Residential Wall Types |
Sun, Mar 21, 2010 at 11:30:12 AM
Members: | 2105921 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
