34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cannot Create Custom Curtain Panel On Curved Surface
Sun, Apr 10, 2016 at 8:29:05 AM | Cannot Create Custom Curtain Panel On Curved Surface
YahyaMohammed
I have this curved surface , and it doesn't allow any panel to be placed except a system panel. Is there a way around it ?
Mon, Apr 11, 2016 at 7:22:33 AM | Cannot Create Custom Curtain Panel On Curved Surface
The problem is probably your panel because Revit will place any properly defined panels.
Mon, Apr 11, 2016 at 4:19:45 PM | Cannot Create Custom Curtain Panel On Curved Surface
YahyaMohammed
Actually No, It doesn't even allow native panels "single glass, double glass doors" to be attached , only the system panels are allowed.
Mon, Apr 11, 2016 at 7:21:47 PM | Cannot Create Custom Curtain Panel On Curved Surface
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I would agree with the meister "Hub. There's something shady in the panel family that is getting thrown off by that geometry. It looks as though your form is almost dome shaped. Are you using a curtain system generated from a mass instead of a simple curtain wall? If so I know some other tricks that could help you out. Either way, if you have a family or model to upload that would assist in diagnozing your issue there.
Slope Roof with custom curtain panel
Fri, Dec 4, 2009 at 12:35:08 AM
custom shape of curtain panel results in panel replacing
Mon, Apr 12, 2010 at 12:17:28 PM
Wood Screen - Curtain Panel
Sat, Jan 10, 2015 at 1:44:00 AM
Loading Custom Curtain Wall Panel into file
Mon, Sep 15, 2014 at 9:19:41 AM
Custom panel family within a curtain system
Tue, Nov 3, 2009 at 11:59:10 AM
Page generation time: 2.6409
