33 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Invisible Building Elements
Sat, Apr 9, 2016 at 3:32:55 PM | Invisible Building Elements
Zylork
I've encountered a problem that has happened before and I don't know how to alleviate it without restarting the entire project. Here's the issue:
I have a building file that I've been working on for a while. I recently opened the file and drew a model line extended from the building model and then drew another line from the first. This was the setup so I could mirror the building. I successfully mirrored it and the mirrored building is visible in plan view but it isn't visible in 3D axon view. It is however visible in 3D perspective but that's not helpful.
Does anyone have any suggestions?
Much appreciated!
Sat, Apr 9, 2016 at 6:45:30 PM | Invisible Building Elements
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Is your 3D view cropped by the section box perhaps?
Sun, Apr 10, 2016 at 9:59:13 AM | Invisible Building Elements
Zylork
That may have been it. Do you know how to disable the section box so I don't need to keep readjusting the cut as I expand outward?
Columns Must Be Invisible Behind the Walls
Fri, Sep 2, 2016 at 10:43:12 AM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:19 PM
Radial array in families
Wed, Nov 24, 2004 at 5:23:30 PM
Invisible truss elements
Fri, Feb 12, 2010 at 10:56:20 AM
Invisible Dimension Lines
Thu, Dec 29, 2011 at 6:04:49 PM
Page generation time: 0.8461
