Forums >> Revit Building >> Technical Support >> Sweep Corbelling Trim on the Corner
0 Posts No Rating |
Hello there,
Do you know how to trim the sweep corbelling corner? Please see picture here. I struggle with it. Somewhere will auto join but some not. I don't know why.
Your help will be appreciated.
Kind regards,
Bogumil
Do your sweep all in one by picking consecutive walls, not seperate sweeps. The corners will then be correct.
0 Posts No Rating |
Most I use sweep under Wall/ Edit Type/ Structure: Edit/ Sweep, and sometimes I use sweep under Architecture tab, click on Wall and then click on Sweep.
You see this picture, it is column not wall. Column not host the sweep, I have to pull sweep over.
I experiment what you said, It looks not successful. Maybe I miss something.
Let me know to how to solve this problem?
Many thanks,Bogumil
Don't do this in your wall - none of them. Do them all as one wall sweep picking the walls one at a time then come back and drag that wall over the column. Here is mine and it works just fine if you do as I directed.
0 Posts No Rating |
I got it and it went successful. Very simple. Thank you for your tip and your time :-)
Corner Trim with Vertical Sweeps |
Thu, Aug 31, 2017 at 2:32:52 PM
trimming trim corner. |
Wed, Feb 1, 2012 at 12:09:42 PM
trim/extend to corner |
Thu, Nov 4, 2010 at 6:10:32 AM
Help! Forgot how to trim with a radius corner. |
Mon, Jan 8, 2007 at 8:25:36 AM
corner trim |
Fri, Apr 2, 2004 at 2:17:40 PM
Members: | 2100983 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
