47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> ROUNDING VALUE ON PROPERTY LINE BEARING
Thu, Apr 7, 2016 at 1:51:12 PM | ROUNDING VALUE ON PROPERTY LINE BEARING
PaulM3357
This item just come to attention recently.  I imported a survey's DWG file in REVIT 2016 and started tracing the property line by picking the line in the AutoCAD file.  When I finish tracing the boundry, I added property line tags to the new property line in the REVIT model. In the surveyor's dwg file the property line's bearing are all round to the nearest minute. The property line tag in the REVIT model are showing fraction of second in the bearing. I looked at the project unit setting and also in the family file of the property line tag.  It seems to me that the property line's bearing cannot be round to the nearest minute.  If someone can offer advice on how to adjust the rounding value of property line's line's bearing will be greatly appreciated. Thanks is advance for your help!
Best Regards,
PaulM3357
Thu, Apr 7, 2016 at 2:03:58 PM | ROUNDING VALUE ON PROPERTY LINE BEARING
If you just want to show a line, then do that but don't label property lines if they are incorrect.
You really should only use a legal property description and that should be available from your surveyor.
Fri, Apr 8, 2016 at 1:13:38 PM | ROUNDING VALUE ON PROPERTY LINE BEARING
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
generally I don't trace the surveyor's lines I use the property line generator by following the surveyor's lines around in the clockwise direction. once generated this line can be placed over the dwg background and lined up with the surveyor's lines.
Property Arcs - Input Delta Bearing
Mon, Mar 13, 2017 at 3:28:27 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:58 PM
Property Line Dimensions
Tue, Jul 13, 2010 at 4:20:28 PM
Property line
Tue, Oct 13, 2009 at 5:31:58 PM
Property Lines
Sat, Oct 6, 2012 at 11:03:51 PM
Page generation time: 0.7020
