122 Users Online (121 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Bevel Siding
Fri, Apr 1, 2016 at 2:14:29 PM | Bevel Siding
rcobbjr
3.5 Stars: 3 Votes
I am using a reveal to add wood beveled siding to a wall. I see the reveal in the section view when I am creating the wall structure however the reveal is not showing up in the model when I look at it in 3D. When I click on the wall I applied the reveal to I can see the ghost image of the reveal. I can only see them when I click on the wall.
I was using a sweep to create the bevel siding but when I went to attach the wall to the roof, it exposed the building paper where the sweep butted against the roof where it sloped. I was hoping using reveal would resolve it. Any ideas?
Sun, Apr 3, 2016 at 10:46:42 AM | Bevel Siding
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Can you adjust the position of the reveal. It may be buried within the wall completely and just need to be shifted outward to cut through the outer plane.
Mon, Apr 4, 2016 at 8:07:35 AM | Bevel Siding
3.5 Stars: 395 Votes
Reveals will overload your project and they will not work at gable ends.  The best process is to simply use a material then add detail components where required.
If you think you must model, check out my initial post here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=17944
Fri, Apr 8, 2016 at 9:23:23 AM | Bevel Siding
coastalclimbing
WWHUB is right!
Siding Sweep Return
Sun, Oct 30, 2011 at 5:57:53 AM
Metal siding
Mon, Mar 16, 2009 at 9:44:10 PM
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Walls with siding
Tue, Feb 28, 2006 at 5:21:50 PM
How do I miter/bevel a wall edge?
Fri, May 15, 2009 at 11:59:22 AM
Page generation time: 0.2337
