108 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> temporary dimensions require me to pan to see them
Fri, Mar 25, 2016 at 9:50:39 PM | temporary dimensions require me to pan to see them
trickhammer
Is there a setting that would force temporary dimensions to appear on the screen rather than in a location that requires me to pan to see them?
Sat, Mar 26, 2016 at 7:52:07 AM | temporary dimensions require me to pan to see them
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi, By a temporary dimension do you mean a dimension that appears when you use the ruler/measurement tool?
If so, no thise measurements disappear once you finish using that tool.
If you need a dimension a bit more permanently just put a proper dimension on it, use it for what you need and then delete it.
Sat, Mar 26, 2016 at 8:54:34 AM | temporary dimensions require me to pan to see them
trickhammer
I am refering to the blue dimensions that appear when you select an element.  It's just an annoyance.
Sat, Mar 26, 2016 at 9:01:10 AM | temporary dimensions require me to pan to see them
trickhammer
Attached is a screen shot.  The wall selected is highlighted however I need to pan slightly to reveal the dimension located just off the top of screen.
Sat, Mar 26, 2016 at 9:52:41 AM | temporary dimensions require me to pan to see them
It takes awhile to get used to the temporary dimensions.  The best advice I have is don't zoom in so close, this is not CAD.  Revit's automatic snaps don't require you to zoom as close as CAD did.
Wed, Jul 1, 2009 at 10:50:50 AM
Temporary Dimensions and Wall centerlines
Thu, Oct 20, 2011 at 1:31:20 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
Mon, Jun 30, 2014 at 9:57:47 AM
Page generation time: 16.6828
