79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Creating a vertical continuous mullion with a profile edited curtainwall
Tue, Mar 22, 2016 at 10:46:18 AM | Creating a vertical continuous mullion with a profile edited curtainwall
skyman111
Hi all,
Revit 2015
I'm stumped on this one and hope someone can tell me if I'm missing something.
We have a curtainwall where we have edited the wall profile in a way where the top and bottom mullions are angled, not parallel to the ground.  Wehave vertical mullions that have a cap extension on them.  These larger vertical mullions are supposed to run past the top and bottom border mullions.  This is no problem when I'm working with a curtainwall where the profile has not been edited - I just modify those vertical mullions to be continuous at the top and bottom.  But, for some reason, once I have edited the profile of the curtainwall, this is no longer an option.
Can you all think of the best way to model these vertical mullions so that they actually look continuous at the top and bottom?  I've included a small sample image, but this is actually for a rather large CW facade.
Thanks - Sky
Edited on: Tue, Mar 22, 2016 at 10:47:58 AM
Curtainwall edit profile
Fri, Jun 12, 2020 at 7:48:22 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:37 AM
coneptual massing curtainwall mullion issue
Thu, Nov 5, 2009 at 11:54:42 AM
trimming vertical mullions to continuous border mullion
Tue, Aug 13, 2013 at 5:28:06 PM
continuous vertical and horizontal custom mullion system
Wed, May 21, 2014 at 8:53:50 AM
Page generation time: 1.2652
