49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Custom Precast Family
Revit Architecture 2015
I recently learned a new trick of using a curtainwall to create precast walls. I set grid lines every 10' in order to make 10' precast sections along the curtainwall. I am creating a custom family so that the precast will have reveals in it. I started a new family under "curtain wall panel" template to get the precast to look the way I want. When I load it into my project and select the 10' wide curtain panel and change the type to my custom precast section, it inserts a panel that is 14'-6 1/2" wide rather than the 10' that I created it as and the 10' curtain panel I have selected. In the properties of the custom panel when selected even says it is 10 wide, but it is actually the 14'-6 1/2" width.
Any ideas why this is happening?
Thanks
You are using a curtain wall....curtain wall panel sizes are defined by the curtainwall.
Although you can make curtainwalls work somewhat for panelized walls, I think this process is very awkward. I prefer using normal walls and using a void family. See my post here. You can create a family to identify, tag and schedule each panel.
That sounds like a good method. However, I am not very confident with creating, loading, and using my own families yet. How would you create this void family?
Thanks again
Attached is the look I am trying to achieve for my panels. The reveals are 1" wide by 1/2" deep. I belive what you suggested earlier was a way to divide a wall into sections.
Wall family |
Fri, Jan 4, 2008 at 4:37:01 PM
cantilevered stone stairs |
Thu, Feb 22, 2018 at 2:30:39 PM
Custom Precast Wall Panel |
Wed, May 20, 2015 at 3:10:54 PM
split precast wall |
Fri, Nov 24, 2017 at 1:17:55 AM
Precast embed connections |
Wed, Jul 30, 2008 at 11:22:13 AM
Members: | 2016882 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
