158 Users Online (157 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ext brick stairs
Fri, Mar 18, 2016 at 10:30:48 AM | Ext brick stairs
GLKIRK
Can anyone tell me if Revit 2013 will make a set of brick exterior steps to a brick porch or do I have to use a monolithic stair and try to draw a brick wakk under it?
Thank you
Sat, Mar 19, 2016 at 10:45:24 AM | Ext brick stairs
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
The stair tool is great for standard stairs but as soon as your stair design gets a bit different it can struggle.
The tool is also a ittle tricky to use to begin with (along with the railings tool).
As an alternative you can make the stair as an in-place family and use extrusions to shape the treads and risers and use walls to form the walls on the sides.
openings in walls
Tue, Feb 3, 2009 at 11:06:48 AM
Shared parameter from View to Sheet
Fri, Oct 9, 2020 at 9:04:19 AM
Crown mouldings on a brick wall?
Sun, May 31, 2009 at 8:38:52 PM
Adjust Brick veener to move down agianst the brick ledge.
Thu, Jul 26, 2018 at 2:23:14 PM
Brick Colour
Mon, Jan 13, 2014 at 9:27:04 AM
Page generation time: 1.0803
