52 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Cut hole for window in timber cladding?
Hi
I know it's a basic task, but this ones is beating me at present. I have made up a SIPS wall construction then added a western cedar timber cladding (BIM store) to the face of the wall which is a present separate to the SIPS wall.
For some simple reason I cannot cut the window openings out or bring the window forward to show through, as it will not allow me.
Do I have to attach the claddingto the wall component some how or is there a different way to do this.
Any tips would be most appreciated as only just starting out with Revit (2013).
Or links to videos/posts.
Many thanks
Use the join tool and join the two walls.
Hi, thanks.
The cladding is classed as a curtain wall and doesn't allow me. It talks about add and remove segments.
Is it easier to form a new wall component somehow?
I think yo are meant to use empty panels in curtain walls somehow to make the opening, I will try and find out how.
Sorry - you did not say this was a curtain wall. I don't think using a curtain wall for panelized walls is a good process.
Timber cladding with occasional colored panel |
Wed, May 4, 2011 at 9:35:02 AM
Timber External Cladding BOard / Weather Board |
Wed, Mar 31, 2010 at 10:02:29 AM
Timber cladding (hit or miss style) in revit architecture 2012 |
Tue, Nov 6, 2012 at 9:08:59 AM
window not cutting joined roof |
Mon, Mar 6, 2017 at 4:23:50 PM
Cut Pattern - Timber Columns in plan views to black ? |
Tue, Mar 18, 2014 at 7:41:46 PM
Members: | 2056165 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
