59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Sign ceiling based (generic model) below distance from level - PARAMETER
Sun, Mar 6, 2016 at 6:56:10 AM | Sign ceiling based (generic model) below distance from level - PARAMETER
allan120791
Hi, I've created a family with different types of signs which are ceiling based (generic model ceiling hosted).I want to create a instance parameter (to be shown in schedules inside my project) that shows the distance from the level (like the sill of a window), but I have no idea how to do that! Can somebody help me? I mean, if is possible with a window, why is not possible to assign the level to a parameter in a generic model ceiling based?See image above with 2 different types of sign:Sign ceiling based (generic model) below distance from level - PARAMETER-capture.jpg
Sun, Mar 6, 2016 at 12:37:08 PM | Sign ceiling based (generic model) below distance from level - PARAMETER
Bartholomew
5 Stars: 2 Votes
Place a Dimension from the underside/bottom of the sign to Level 1 and Parameterize that dimension as an instance-reporting type.
Edited on: Sun, Mar 6, 2016 at 12:56:07 PM
Mon, Mar 7, 2016 at 1:25:59 PM | Sign ceiling based (generic model) below distance from level - PARAMETER
allan120791
Yeah, I've already done that, but unfortunately the height showing in parameter [3,00m] (when loaded in the project) is not matching to the distance of the bottom of the sign [1,67m]. In any sign height I use inside my project, there's always a difference of 1,33meters... I don't know why... Look:
Mon, Mar 7, 2016 at 1:40:00 PM | Sign ceiling based (generic model) below distance from level - PARAMETER
Bartholomew
5 Stars: 2 Votes
Post a screenshot of your family's type parameters please. Better: post a screenshot of your family parameters as defined in the family itself.
Edit: Verify the ORIGIN Plane in the Family.
Edited on: Mon, Mar 7, 2016 at 1:46:59 PM
Ceiling Based Family Issues
Thu, Oct 13, 2005 at 7:07:47 AM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:19 PM
Ref Level model lines in Ceiling based family
Thu, Apr 23, 2009 at 10:01:50 AM
Ceiling-based Components- Changing ceiling size
Thu, Jan 5, 2012 at 9:39:53 AM
Lines in Ceiling Plans
Wed, Oct 24, 2007 at 4:44:58 PM
Page generation time: 2.8197
