Forums >> Revit Building >> Technical Support >> Loading families results in a serious error?
Hello there, I have a very frustrating problem that I am trying to remedy.
I have been tryinig to load some famlies into my revit project and for some reason every time that I do I am met with the same "A serious error has occured, it is recommended that you save" blurb.
Here are the things that I have attempted:
I was running revit 2015 a first: I reinstalled the libraries, repaired the libraries then eventually did a complete uninstall.
After downloading revit 2016 I was hoping that would be enough, it wasn't. I did the same reinstallation, and repair and the problem has persisted.
I have contacted autodesk, but their customer service as far as a phone call goes is awful.
I have also uploaded a video to youtube to better illustrate the problem that I have been having.
https://www.youtube.com/watch?v=cuPBxTyytGw
Can anyone help me? This is very frustrating...
If you're on subscription, just log into your acount and create a case. Autodesk Support is generally pretty quick. Typically I get a response within 48 hours.
One thought, try changing the directory path to your libraries; path it to 2015's libararies and see if 2016 will load those.
I do not have a subscription unfortunately, but I did post this to their forums.
I do not have the 2015 libraries as I did a full uninstall after this problem started, right before I installed 2016. The 2015 libraries is where the problem originated, though.
Did you do a clean uninstall of 2015?
I`m not sure what you mean by that.
I uninstalled everythhing, from the program itself, to every single content library.
Google it. CLEAN UNINSTALL REVIT.
Hey mate, sorry for the late reply. I have been away from internet access for the past week.
Did the clean uninstall and reinstall and nothing changed. I did however get ahold of a revit specialist from Autodesk finally and he diagnosed the problem as being graphics related, specifically I need to get a new graphics card; my current stock card is not on autodesks list and as such wonte render.
Hoping he's right!
H
Loading Families |
Mon, Nov 23, 2015 at 7:25:45 AM
Issues with loading downloaded families |
Thu, Jan 9, 2014 at 12:11:36 PM
Not All Downloaded Revit Families Appear After Loading |
Sat, Mar 19, 2011 at 12:21:22 PM
error when loading components |
Wed, Dec 1, 2010 at 2:33:54 PM
A fatal error loading family into project overwriting existing |
Mon, Jun 22, 2015 at 8:03:38 AM
Members: | 2119097 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
