100 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> Conditional toggle yes no formula
16 Posts No Rating |
I am trying to control 3 visibility states but I only want one toggle on at a time. I know how to control 2 with a yes/no and a "not" condition, but I can't figure out how to control 3 yes/no so that only 1 is on at a time. Any help would be greatly appreciated.
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
I have done this before using a control integer value. When the integer value = 1 then the first item is visible, when it is = 2 then the second item is visible and so fourth. I would also add a text parameter that staes "Toggle visibility by cycling integer between 1 and 3".
the visibilty parameters would look something like this.
integer = 1 (this would turn item 1 on when the integer is 1)
integer = 2
integer = 3
That is similar to how I have had it set up, but it isn't the solution I am looking for. Trying to make this dummy proof. Thanks for the suggestion.
As off current that is the simplest way to do it with just one control
conditional formatting yes no parameters |
Tue, Oct 28, 2008 at 9:58:54 AM
Family types - conditional statement |
Mon, Apr 18, 2011 at 3:59:50 PM
Schedule Parameter formula not showing up [ 1 2 ] |
Thu, Oct 28, 2010 at 4:33:57 PM
23
Repeating Detail in Families |
Tue, Aug 10, 2010 at 9:14:20 AM
Yes/No Conditional on No/Yes |
Tue, Nov 11, 2008 at 12:21:06 PM
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
