58 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> resizing CAD
Wed, Mar 2, 2016 at 6:22:45 PM | resizing CAD
glenlake
3.5 Stars: 3 Votes
Fear experts;
please help me to figure out what is wrong.
Goal: to resize (scale) inserted CAD in an Section/Elevation view
I have two scenarios:
A: .dwg 1 is perfectly scalable in one project but in another project it, when placed in sections and elevations,
makes "Scale" button gray (not available).
B. the second .dwg, when inserted in sections/ elevations of both projects, when selected, makes "Scale" button grayed out.
In Revit project No.2 NONE of the inserted CAD drawings allow to scale them, even though they were OK in different Revit projects.
I will appreciate any suggestions.
(everything is unpinned, prior to inserting i purged anfd flattened .dwgs. Revit 2014)
Thank you.
Wed, Mar 2, 2016 at 7:19:34 PM | resizing CAD
Bartholomew
5 Stars: 2 Votes
Why do you need to scale them?
Edited on: Wed, Mar 2, 2016 at 7:21:07 PM
Thu, Mar 3, 2016 at 7:22:19 AM | resizing CAD
glenlake
3.5 Stars: 3 Votes
Just because they were drawn in CAD (in model space) not in 1 to 1, but bigger.
Thu, Mar 3, 2016 at 8:45:38 AM | resizing CAD
Cad is not an image and is not scalable.  When importing, you can set the units.  You can also open the CAD and scale it there.
Thu, Mar 3, 2016 at 11:44:52 AM | resizing CAD
glenlake
3.5 Stars: 3 Votes
Thanks.
But how come that i am able to scale the CAD files in some views, but in others -- not?
Thu, Mar 3, 2016 at 3:51:25 PM | resizing CAD
I'm sorry, I was incorrect.  Just unpin and scale it.
I must be getting stupid...
Fri, Mar 4, 2016 at 3:43:32 PM | resizing CAD
glenlake
3.5 Stars: 3 Votes
ll the AutoCad drawingd, inserted in Revit, are unpinned. I think it might depend on the Section View properties. In that Revit file, in all section/elevation views none of the inserted .dwgs are unscalable.
And one drawing in unscalable in another Revit file, where the first .dwg is perfectly scalable.
 Thank you.
Fri, Mar 4, 2016 at 3:48:01 PM | resizing CAD
Was the dwg inserted "this view only"  or not?
This view only is 2d.
Mon, Mar 7, 2016 at 10:02:30 AM | resizing CAD
glenlake
3.5 Stars: 3 Votes
No, i rarely use "This View Only".
The AutoCAD drawing is flattened, purged, looks normal.
I think, in one case there is something with a view properties in Revit.
But in te other case, when one .dwg is scalable, but the other -- not - is a CAD file problem.
What do you think?
Mon, Mar 7, 2016 at 1:21:10 PM | resizing CAD
Bartholomew
5 Stars: 2 Votes
You say the ACAD drawing is “Flattened”? Hmm…I do remember having similar issue couple of years ago. Sorry, I cannot remember exactly how I resolved, but I do remember it wasn’t resolved through Revit. I had to go back to ACAD drawing to fix; that the issue was related to the FLATTEN command. I believe I resolved by using OVERKILL and then CHANGE to zero out elevations.
Tue, Mar 8, 2016 at 8:05:28 AM | resizing CAD
#11
glenlake
3.5 Stars: 3 Votes
Thanks. Never heard about OVERKILL command. I'll try it. I hope it would help. (I thought, that FLATTEN equalizes all the zero values)
But this won't solve the problem with the second >CAD file, which is OK for scalind in the first Revit project, but does not work in the second one.
(unpinned, placed in Sections and elevations).
Viewport textbox resizing? :S
Thu, Oct 21, 2010 at 1:00:45 AM
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:51 AM
view-specific resizing?
Thu, Aug 23, 2007 at 8:13:14 PM
Revit to CAD then use current cad layer standard, how?
Sat, Mar 10, 2012 at 8:42:46 AM
Resizing topo?
Sat, Dec 5, 2009 at 7:16:50 AM
Page generation time: 1.8591
