Forums >> Revit Building >> Technical Support >> Lighting Rendered
5 Posts No Rating |
I need to represent in a rendering, colored lighting. Is there a way to adjust the RGB of an instance or type of light fixture? Does the light always have to render white?
Please help.
4 Posts No Rating |
I have the same question, hopefully someone can help.
admin
I believe the only way to change the color of light is to surround the source with a colored translucent surface.
Hiroshi Jacobs
The Catholic University of America |
there is a
Purple Pavement Uplighter for exterior or interior use. Just edit the lens colour in families for different light colours.
It was posted by gary553
best regards,
coreed,aia
20 Posts No Rating |
OK. Thanks.
I havent been able to d/l yet because of server error. I'll try again shortly.
4 Posts No Rating |
I was forbidden to download the "Purple Pavement Uplighter",is there any limitation for that?
i think it is a server problem, hopefully ADMIN will fix it soon
best regards,
coreed,aia
Post edited on 2006-04-07 17:06:22
Rendered Lighting Help |
Tue, Apr 14, 2015 at 12:09:53 PM
Lighting comes out psychodelic when rendered |
Fri, Aug 8, 2014 at 9:46:09 AM
Interior Lighting - lights stay dark when rendered |
Sun, Oct 25, 2015 at 4:27:52 AM
cove lighting? |
Wed, Dec 7, 2011 at 2:23:00 PM
lighting fixtures |
Fri, Jul 26, 2013 at 9:45:43 AM
Members: | 2122563 | Objects: | 23210 | Forum Posts: | 152313 | Job Listings: | 3 |
