114 Users Online (114 Members):
Forums >> Revit Structure >> Technical Support >> Wood Stud Wall Cut Patterns
0 Posts No Rating |
We model many multi-level, residential wood buildings. I need to know if there's a way to denote out third type of wall's cut pattern.
First type is Wood Stud bearing wall which we assign a solid fill to the coarse fill pattern.
Second type Wood Stud shear wall which we assign a small diagonal fill to the coarse fill pattern.
Third is a combination Wood Stud Bearing and Shear Wall. Is there a way to assign both a solid (shaded) fill and a diagonal line fill to the single family type? Or using a filter override?
Thanks,
Marvin L Infante
BIM Technician
Denver Colorado |
I'm not exactly sure what the question is. A sketch goes a long way in describing this type of thing.
You can not assign two different fill patterns to a coarse wall.
Wood Stud wall |
Thu, Feb 12, 2009 at 9:05:51 AM
Wall cut patterns |
Fri, Jun 16, 2006 at 1:29:23 PM
Wood frame projects |
Mon, Nov 14, 2016 at 3:41:23 PM
Wall Cut Pattern Plan View vs. Section |
Fri, Jan 6, 2012 at 11:19:21 AM
How to create a 2x6 wood stud |
Wed, Oct 16, 2013 at 2:24:57 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
