80 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> True North vs Project North Linked dwgs
Thu, Feb 25, 2016 at 9:52:29 AM | True North vs Project North Linked dwgs
NobleLP
I have the project true north and project north set up, I set the floor plan view to true north and Link the dwg orig to orig, aligned to view cleared and this view only checked, this file links in perfectly. I change the view to project north and everything is good. I crop the vew and work on the project, after moving from view to view or colsing the project and reopening the file, I descovered that the linked dwg has lost the true nort / project north orentation. after many relinks, audits, and any thing eles I can think of the problem persists.
Any ideas as to the remeady?
Sat, Feb 27, 2016 at 11:20:14 AM | True North vs Project North Linked dwgs
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I have seen this. Can't remember exactly what the solution was . . . . is anyone esle working on this project besdis you ?
Tue, Mar 1, 2016 at 3:13:39 PM | True North vs Project North Linked dwgs
NobleLP
YES
The linked files are floor plans in ACAD where the team is continuing to develop backgrounds from the Designer
Tue, Mar 1, 2016 at 3:20:12 PM | True North vs Project North Linked dwgs
Isn't this problem caused by the fact that Revit treats a "This view only" as a annotative type element?  Thus it really has no orig to orig link any longer.
Maybe unchecking that box and using a workset to control what views this linked CAD will show up in will work correctly.
Thu, Mar 10, 2016 at 10:02:26 AM | True North vs Project North Linked dwgs
NobleLP
I belive the problem stems from the model being too far from the internal origen, I re-created the model putting the model at the internal origen and utilized the shaired coord. system and things have setteled down.
DUH!!
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
True North / Project North spelled out
Sun, Jun 10, 2012 at 1:41:04 PM
EXPORTING TO FBX TO TRUE NORTH
Wed, Sep 9, 2015 at 7:36:58 AM
True north help
Tue, Jul 21, 2015 at 3:52:04 PM
Page generation time: 1.2423
