80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing Glazing
Mon, Feb 22, 2016 at 3:43:10 PM | Changing Glazing
eltazar
Hi all, I have a louvre window family which I have been using for several years. I have just upgraded the family and started using REVIT 2016. I have noticed an interesting problem with the family after upgrading to 2016 which is that if I change the width the of the window to exact 900mm the glazing changes from our standard clear colour to a blue glazing even though the material has not changed and in the Windows properties remains as the same material. The only change is the width of the window. To make it even more interesting if the width of the window is either 899mm or 901mm the glazing remains as our standard clear colour. Would be very interested for any theory's or thoughts to fix the problem. Thanks in advance.
Tue, Feb 23, 2016 at 6:59:01 AM | Changing Glazing
I would have to see the family.
Tue, Feb 23, 2016 at 5:03:43 PM | Changing Glazing
eltazar
Here is the family. place it in a project and try adjusting the width 899, 900, then 901.
Tue, Feb 23, 2016 at 7:29:44 PM | Changing Glazing
Bartholomew
5 Stars: 2 Votes
Nothing out of the ordinary happening at my end. Using 2016. Your family is using standard OOTB material asset at my end. Non-shared. Have you looked into the Materials Libraries you've got loaded (or not loaded)? Any Errors?
Edited on: Tue, Feb 23, 2016 at 7:30:05 PM
Tue, Feb 23, 2016 at 10:23:32 PM | Changing Glazing
eltazar
Hmm. That's odd. Have tried this again in a new 2016 project. The material does not change when the width is set to 900mm only the colour of the glass when in a shaded 3D view from clear to blue. What and where should I look for the material library errors? I did a full standard install of Revit building design suite 2016.
Wed, Feb 24, 2016 at 9:09:19 AM | Changing Glazing
Bartholomew
5 Stars: 2 Votes
Happens to me sometimes too with 2016: Revit Material Library path are suddenly lost or just not loaded (path is replaced with yellow & red error icons). A relaunch quickly fixes it. Don’t remember this with happening with 2015, or any previous version for that matter.
Glazing
Tue, Sep 15, 2009 at 1:09:55 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:15 PM
Glazing Transparency in Realistic View
Wed, Jun 6, 2012 at 8:51:54 AM
Problem with glazing and wall alignments
Thu, Jan 24, 2013 at 10:17:00 AM
Tell me again how to make "sloped glazing" look like metal roofing?
Wed, Jun 11, 2008 at 9:43:35 AM
Page generation time: 0.8285
