Forums >> Revit Building >> Technical Support >> tiling windows
is there a way to have the windows tile side by side as opposed to on top of each other when you tile the open windows? (this is related to a dual monitor set up and spending a couple weeks detailing out wall sections.
Don't think so, window tiling is automatic based on how many views you have open. You could manually rearrange window sizes and positions though...
yeah, thats what i have been doing. what can i say? i am spoiled and lazy.
15 Posts No Rating |
Bump to this. Can we put this on a wishlist? It is a MAJOR pain in the rear (and a dumb design, IMNSHO) to have the tiling of 3 windows place the full length window on the right. But, barring that little change (swap the 2 for 1 left/right), I would much prefer to be able to customize my tiling and save the settings based on how many windows are open. Basically, give me God-like control over the tiling! And do it yesterday, if you don't mind.
Helping you Be Able to be the person you want to be! Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com |
3 Posts No Rating |
Super Bump! Still no Tile Vertically option with Revit 2010... which is BS considering I assume the majority of users run dual monitors. I run Revit stretched across dual 24" widescreens, and needless to say WT is completely useless. I would love a shortcut to tile vertically instead of having to do it manually. Completely unacceptable Autodesk! End rant.
ultra bump!
Still no setting in Revit 2015... oh well, we will just have to accept that Autodesk likes designing gimicks for newer releases instead of perfecting workflow
We recommend that you always read the similar threads like the one that points to this app:
https://apps.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3apalladioxbimwindowslayout%3aen
Tiling windows |
Thu, Jan 30, 2014 at 2:20:43 PM
Adjust hatching to follow brick courses or tiling for tiling layouts |
Tue, Aug 5, 2008 at 10:14:13 AM
Tiling Layout |
Wed, Oct 6, 2004 at 1:28:50 AM
Placing filled regions for tiling in bathrooms |
Fri, Jun 10, 2005 at 10:35:12 AM
Tiling Seamless Texture Images |
Tue, Oct 12, 2004 at 8:08:16 PM
Members: | 2102216 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
