73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Creating an angled cellar door
Thu, Feb 18, 2016 at 5:41:11 PM | Creating an angled cellar door
6slinger
1 Stars: 1 Votes
Hi
Anyone tried to make an angled cellar door?  I tried to rotate a wall. I 've tried a trianglar mass.  Need some outside the box thinking because ifI remember right walls in revit like to go striaght up and down.  I thought that I might be able to make the angle of a triangluar mass into a wall and drop an door in that butno luck.
Thank you
Kirk
Thu, Feb 18, 2016 at 6:56:01 PM | Creating an angled cellar door
Bartholomew
5 Stars: 2 Votes
Not following you. "Angled cellar door?" Regarding walls: they can be non-perpendicular to the floor. Wall By Face. If you want a pendendicular door in a non-perpendicular wall, use a void extrusion, instead of an Opening, and make it deep enough to cut an entire opening through the angled wall.
Edited on: Thu, Feb 18, 2016 at 6:56:36 PM
Barrel Vaulted Cellar
Fri, Mar 12, 2010 at 12:12:04 PM
Revit 2011, Creating a wall with an angled end.
Wed, Feb 7, 2018 at 10:55:54 AM
"Cant Make Door" Warning
Thu, Oct 23, 2014 at 2:45:10 PM
angled roof / wall
Wed, Feb 20, 2008 at 9:30:55 AM
Angled Walls in Revit
Mon, Jan 12, 2015 at 8:48:27 AM
Page generation time: 0.5658
