Forums >> Revit Structure >> Technical Support >> Knoll Revit Families Not Rendering
Thu, Feb 18, 2016 at 4:00:34 PM | Knoll Revit Families Not Rendering
snydem2
Hi!
I downloaded a Revit family from the Knoll website for a design I am working on. In the family, I changed the fabric of the seating, however the materials do not appear in the realistic views or rendering in my full project. Instead, they are just a flat grey. Is this a Knoll preference, a user error, or is there any way to fix this?
Thanks in advance!
Thu, Feb 18, 2016 at 4:19:59 PM | Knoll Revit Families Not Rendering
3.5 Stars: 395 Votes
Probably user error.  Grey is a default color which means you did not re-assign a material.
REMEMBER - THE PROJECT RULES!  Once a material is assigned in the project to an element (either by loading the family or direct assigning in the project), it can only be changed in the project.
Sat, Mar 19, 2016 at 7:37:57 PM | Knoll Revit Families Not Rendering
riannemcdonald
I am having the same problem. Can someone explain the solution here? I've tried to fix in the family, but it won't show up once I put the family in my project.
Mon, Mar 21, 2016 at 7:56:39 AM | Knoll Revit Families Not Rendering
You need a better understanding of materials and how you apply them.  Also read my post right above yours.
need Knoll furniture 3D symbols
Wed, Sep 12, 2007 at 10:14:57 PM
Websites for Revit Families
Wed, Mar 6, 2013 at 6:33:55 AM
Rendering Families in Revit 2010
Mon, Jul 19, 2010 at 5:39:45 AM
Rendering...
Fri, Aug 8, 2008 at 2:43:22 AM
How to Remove Furniture Tags
Mon, Dec 18, 2017 at 9:54:11 AM
Page generation time: 3.2974
