89 Users Online (88 Members):
Forums >> Revit Structure >> Technical Support >> Strange "constrain" issue when copying.
A coworker (pretty new to revit) just called me over. He's trying to move some purlins along a plane and not constrained. When he chooses "multiple copy" and un checks the constrain box, it rechecks each time he hits enter or clicks the position of the copy. I have the same version of revit (2016) and mine doesn't do this. I assume it's an options thing but I don't know where to look. any thoughts? Thanks, paul
it is likely due to the fact that the purlin is hosted on another model element and so it defaults to making you only be able to move it along the hosting element or plane. I am not sure if there is a way to change the default so it is not constrained when moved
command move then check disjoint.
Edited on: Thu, Feb 25, 2016 at 6:52:41 PM
"command move then check disjoint.
Strange things are happening when copying a group |
Wed, Mar 24, 2010 at 3:19:28 PM
Array Error |
Tue, Nov 10, 2009 at 1:29:33 PM
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:49 PM
"ADA Clearances" in families |
Tue, Sep 11, 2012 at 10:34:16 AM
When I copy an "existing" element it reverts back to "new construction." |
Mon, Jun 16, 2008 at 2:38:24 PM
Members: | 2022270 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
