54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to create revit family from cad 3d drawing
Wed, Apr 5, 2006 at 8:03:22 AM | how to create revit family from cad 3d drawing
zubair
halo! if i draw a 3d object in cad (dwg), how do i turn it into a revit family (rfa) drawing? please advise step by step thanks!
Wed, Apr 5, 2006 at 8:25:32 AM | RE: how to create revit family from cad 3d drawing
coreed
coreed Avatar
4 Stars: 16 Votes
step by step Step One. Don't best regards coreed,aia
Wed, Apr 5, 2006 at 8:59:23 AM | RE: how to create revit family from cad 3d drawing
TomDorner
4.5 Stars: 25 Votes
Take a look at the "How to grow your family..." tutorial on this site. I wouldn't start a family from scratch using AutoCAD, but if the AutoCAD geometry exists then it is perfectly acceptable to re-use it in a non-parametric Revit family. Most of the Revit web library from Autodesk itself uses this technique. Tom
Mon, Apr 28, 2008 at 4:44:22 PM | how to create revit family from cad 3d drawing
jjlangh
jjlangh Avatar
3 Stars: 2 Votes
I received some CAD 3D furniture from a furniture specifier and am trying to make it usable in Revit. Unfortunately when i just import it as a CAD drawing it appears solid black in plan becuase of all of the contour lines. Is there a way to convert it to a Revit family or Sketch-up file?
Tue, Apr 29, 2008 at 4:32:09 PM | how to create revit family from cad 3d drawing
lunchtrayrider
3.5 Stars: 7 Votes
If you created the family but are only having problems with too many contour lines then just put some symbolic lines in plan and turn the 3-d object off in plan.  This is most likely the fastest solution but not the sexiest.
I like scooters. and motorcycles.
Xclip an inported CAD image in Revit
Wed, Aug 4, 2010 at 2:26:13 PM
CAD import to Revit
Mon, Dec 13, 2010 at 3:34:55 PM
REVIT / CAD Coordinates
Wed, Jul 2, 2014 at 9:55:20 AM
export to CAD from isolated view
Fri, Aug 1, 2008 at 9:25:48 AM
Autocad 3d drawing in to Revit?
Sun, Jun 5, 2005 at 8:01:17 PM
Page generation time: 5.1352
