Forums >> Revit Building >> Technical Support >> Wall mounted carriage / lantern lighting
56 Posts No Rating |
Looking for a Revit family wall mounted carriage lamp/lantern that I can change the housing colors on.
There is one in the downloads - search carriage.
I found that one but it is autocad inserted into a revit family, therefor uneditable.
This one is editable.
I wish you would have stated that in your earlier post.
If the autocad file was built correctly, it can stll be controlled. Materials are assigned to autocad solids on a layer basis - you can set this in the project - VG.
The one I had found is not from cad and not sure where it came from. Needless I have searched all over the internet and cannot find anything for Revit. I have found plenty of lamp styles but none in cad nor revit.
This is the one I found on revitcity. I can open it and export it to a cad file. If you change the color it changes everything. If you explode it everything deisappears.
Please pay attention to what we repond with. As I said "If the autocad file was built correctly, it can stll be controlled. Materials are assigned to autocad solids on a layer basis ". Take a look at my image. Do you see the material assignment per layer?
wall mounted toilet wall error |
Wed, May 6, 2009 at 3:41:37 PM
Lantern roof |
Sun, Jun 16, 2013 at 1:08:40 PM
Lighting Units not Rendering |
Mon, Nov 9, 2015 at 7:03:00 PM
14
Handrail - Wall mounted |
Fri, Apr 28, 2017 at 5:35:54 PM
handrail, wall mounted |
Fri, Feb 13, 2009 at 1:47:36 PM
Members: | 2118901 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
