23 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> curtain wall door family always vertical?
67 Posts No Rating |
I have curtain wall that is near plum but is about 10 degrees off. I want the door to be vertical. I go to edit the curtain wall door family and go "family category and paramaters" and there is a parameter for "always vertical, which does not change anything if it is checked or not. Is there a way I can force the family to remain vertical relitave to the floor level?
Revit 2016
Thanks
Do you have an image of the condition you're trying to apply the door too? It's hard to extrapolate from your description.
Curtain wall doors are really a curtain wall panel and will follow those rules. You could place a wall instead of the panel and put a door in that wall.
Thanks guys but my need for this is long gone. The design changed and the project is completed. This thread can be closed. Thanks tho!
Curtain Wall Panel to Curtain Wall Door |
Cant load Curtain Wall Door |
Wed, Oct 26, 2011 at 3:41:44 PM
curtain wall door |
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall vertical mullions won't go vertical |
Mon, Apr 15, 2013 at 6:19:36 AM
12
Curtain wall door frame |
Mon, Mar 2, 2015 at 11:37:33 AM
Members: | 2056491 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
