77 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> Family Type Parameter Value Controlled By Formula Not Grayed Out In Project
![5 Stars: 2 Votes](/images/stars_5.gif) |
Can anyone tell me why I would be able to change the value of a family type parameter, in the project, if that parameter’s value is locked and controlled by a formula?
I have a family (Light Fixture) with a locked “type” parameter value controlled by another “built-in” type parameter in the family (e.g. formula=the built in parameter name/2). My expectation is that, when loaded into a project, I should only be able to change the family’s “built-in” parameter value; that the other parameter’s value would be fixed (grayed out) since it’s controlled by a formula. But this is not the case: both parameter values can be changed in the project – peculiarly, with the formula working in reverse (e.g. “built-in” parameter value doubles when I change the other parameter value).
Build: 16.0.462.0
20150506_1715(x64)
Service Pack 1
Solution courtesy of Andrew K at Reivt Forum:
"To get by this, change the formula for the parameter that you don't want users to be able to control. If(1=1, Formula you want, 0) You can change to whatever true statement you want, if you don't like 1=1."
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Including different formula parameter for each type? |
Wed, Sep 5, 2012 at 1:18:28 PM
formula using <Family type> parameter |
Mon, Nov 1, 2010 at 10:01:58 AM
Parameter names with dashes - problem with formula |
Tue, Aug 31, 2010 at 10:28:39 AM
Members: | 2016987 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
