55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> How to make anchor bolts group??
Hi,
How should i make these kind of anchor bolt groups??
Should i make family, assembly or group, so i could copy them and change them all at same time?
Drawing is in the attachment.
I have have about 10 different type these kind of anchor bolt groups in my foundation projects.
Whats the best way to manage them all and it should be easy to make shop drawings from them like in attachment?
Best regards.
Madis
If you have 10 different types, with the similar configuration just different dimensions, then using parametric famiily makes more sense. Just consider door families, the same panel, trim with different widthes and heights. Otherwise using groups will be fine, to me groups are similar to the blocks in AutoCAD; you modify one, it will apply to all in the project.
Base Plate with Grout ,anchor bolts and nuts. |
Sun, Apr 29, 2018 at 8:25:07 AM
How do I set an equality anchor? |
Thu, Oct 26, 2006 at 7:30:59 PM
can't make change to group with more than one instance [ 1 2 ] |
Sun, May 21, 2017 at 1:30:17 AM
16
Expansion Anchor Table |
Mon, Jan 16, 2017 at 12:50:20 PM
System Family Question |
Wed, Nov 10, 2010 at 9:59:09 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
