35 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> How to inventory used/unused parameters?
Fri, Jan 29, 2016 at 8:48:47 AM | How to inventory used/unused parameters?
XSoph
XSoph Avatar
Is there a way I can quickly list project parameters that are used and vice versa? I am altering a project template that has been in use for a long time and picked up all sorts of bloat. I would like to clear out any parameters that are obsolete, but it's hard to know if something is still relevant until I notice that a schedule or something else has stopped working.
I'm stripping out all the junk I can find.
Thanks all.
Fri, Jan 29, 2016 at 9:32:56 AM | How to inventory used/unused parameters?
Hard to do but you might try this.
  • Start a new clean template.
  • Copy/paste in any schedules you have set up and your titleblocks.
That should get you what schedule/project parameters that you use.
Fri, Jan 29, 2016 at 11:43:11 AM | How to inventory used/unused parameters?
XSoph
XSoph Avatar
Yeah, that sounds like a good ground-up route. Too bad I'm in the middle of the production season and am forced to update the template while it is in use. I doubt anyone before/after me had or will have time to to start from scratch. I'm just applying the housekeeping that was absent before.
Thanks for the reply!
Preset Inventory for Color Schemes - Revit Architecture 2012
Thu, Oct 17, 2013 at 4:19:34 PM
How to delete unused views
Fri, Jan 26, 2018 at 1:19:18 PM
Purge unused Viewport Titles
Thu, Aug 30, 2018 at 10:41:50 AM
11
Create Report of Unused Items to verify before Purge?
Wed, Jun 22, 2016 at 5:18:47 PM
purging unused makes central larger
Mon, Feb 11, 2013 at 10:36:14 AM
Page generation time: 1.0000
