26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Missing Orientation option (Project North/True North) in Properties Palette
Thu, Jan 28, 2016 at 4:48:13 PM | Missing Orientation option (Project North/True North) in Properties Palette
joenunez
I am unsure if it a Revit glitch or the way my file/view was setup, but I am missing the option in the Properties palette of Floor Plan view to switch in between Project North and True North. What would cause this? Has anyone else experienced the Orientation missing also? Thanks.
joenunez
Revit Architecture 2017 \
20170225_1515(x64)
Windows 7 Enterprise SP1 \ Xeon \ 20 GB RAM
Fri, Jan 29, 2016 at 7:42:03 AM | Missing Orientation option (Project North/True North) in Properties Palette
Did you click on that field on the right to see the pull down?
Do you have an applied view template?
Is this view a call-out from another view?
Fri, Jan 29, 2016 at 10:19:00 AM | Missing Orientation option (Project North/True North) in Properties Palette
joenunez
-I am unable to click on that field to the right because that entire line "Orientation | Project North/True North" is not visible in palette.
-No view template applied
-Not a a view callout
joenunez
20170225_1515(x64)
Fri, Jan 29, 2016 at 10:24:13 AM | Missing Orientation option (Project North/True North) in Properties Palette
Create a new plan view ....
Fri, Jan 29, 2016 at 11:17:00 AM | Missing Orientation option (Project North/True North) in Properties Palette
joenunez
so i think the problem might have stemmed from the view having a scope box. Is that possible? I was removing just about everything and after removing scope box and creating a new plan view the Orientation field was visible again. Thanks.
joenunez
20170225_1515(x64)
Fri, Jan 29, 2016 at 11:23:52 AM | Missing Orientation option (Project North/True North) in Properties Palette
Although I don't see anthing in the Help, it does seem plausible that a scope box will affect this.
Thanks for posting this - it gives us a possible answer we (I) did not know.   So many possibilities in user's problems - really hard to ferret out all of the information we need to answer the question.
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
true north & callouts
Thu, Oct 2, 2008 at 11:16:39 AM
export 3d true north
Thu, Mar 16, 2017 at 9:18:30 AM
Page generation time: 5.2022
