23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Openings
Thu, Jan 28, 2016 at 10:10:46 AM | Openings
GLKIRK
May I ask:
The "Cased opening" family does not seem to work in my 2013 version.
How should a person draw a cased opening?
Is there a way to make the door only disappear? or other?
Thank you very much!
Thu, Jan 28, 2016 at 10:57:12 AM | Openings
Best solution - find one that does work.   Why doesn't yours work.
To quickly create a 'cased opening' family:
  1. open a single flush door family,
  2. do a save as xxxx cased opening
  3. delete the door leaf model element
  4. delete the door panel and door swing annotation lines
  5. delete the threshold lines if any
  6. save then load into your project.
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:15 PM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:12 AM
Openings in different phases
Tue, Apr 20, 2021 at 7:23:43 PM
Openings--how do you control constraints?
Thu, Jun 11, 2009 at 1:57:50 PM
face based shapes with openings
Mon, Mar 9, 2009 at 3:10:11 PM
Page generation time: 0.4225
