42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sections not visible in some views
Wed, Jan 27, 2016 at 11:00:51 AM | Sections not visible in some views
Brody1975
Hi,
I'm using Revit MEP 2015 and I have opened an arch model and I"m trying to cut a section in the arch model but it keeps telling me that none of the created elements are visible in the RCP plan that I'm tying to cut the section in. I have checked VG and sections are checked to be on and made sure there are no view templates applied. There must be a setting for the sections to be visible. My work around for now is to create a new view in the arch model and then it will let me cut a section and show up, can anyone enlighten me on this.  I have tried just cutting sections in other arch models before and seem to run into this issue a bunch. I have messed with the hide at scales coarser than 1/8" setting and still can't seem to make this work even if I set it to 400'. Maybe I"m not understanding the setting on this but I'm stumped for now. Any help on this would be appreciated.
Wed, Jan 27, 2016 at 11:20:16 AM | Sections not visible in some views
Revit has a do not show if view is coarser than setting.  Change the view scale to a larger setting and see if the section cuts show.
Wed, Jan 27, 2016 at 11:40:21 AM | Sections not visible in some views
Brody1975
WWhub,
I have increased the scale of the view and I'm still not seeing the sections in the view.
building sections visible but detail view sections NOT visible on all drawings??
Tue, May 27, 2008 at 12:50:21 PM
Sections lines not visible in certain plan views.
Wed, Dec 14, 2005 at 11:30:16 PM
Linked Structural model not visible is certain rotated section views
Tue, Dec 22, 2015 at 2:27:13 PM
11
3D objects not visible in sections but visible in plan & 3D?
Wed, Nov 12, 2014 at 10:58:41 AM
Sections, different level/views
Sat, Aug 5, 2017 at 7:34:45 AM
Page generation time: 4.8794
