Forums >> Revit Structure >> Technical Support >> Custom Linetype Not Showing When Inside of Another Family?
0 Posts No Rating |
Hello all, I'm using Revit 2015.
I've created a custom linetype with text that we use to represent certain reinforcing elements (rebar, mesh, etc.) It works fine whenever I insert it straight into a project. I want this custom "line" to be a part of the rebar family that I've created. While looking at and testing the rebar family by flexing the parameters, the line shows with no problems. But, whenever I insert the "rebar" family into another project, it just shows the line, with no text. Why isn't it showing that text as well? I've included a couple images with the issue.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=5324
0 Posts No Rating |
That link seems to just show how to make the line, which I've already done. The issue comes whenever I try to nest that linetype family into another family.
I tested this and could not get it to work either. I think it is because this line based element is using an array.
How to add new linetype to family |
Fri, Jan 3, 2014 at 10:01:50 AM
Select all of one linetype in a view? |
Tue, Jan 10, 2012 at 3:31:15 PM
spot elevation & custom pipe tag |
Mon, Mar 24, 2014 at 10:29:53 AM
Handy Linetype |
Sun, May 7, 2006 at 8:14:28 AM
Showing objects in higher levels in hidden linetype |
Tue, Feb 21, 2012 at 7:10:08 AM
Members: | 2100620 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
