91 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Revision Clouds and tags on Sheets or in Views?
Wed, Jan 20, 2016 at 9:10:30 AM | Revision Clouds and tags on Sheets or in Views?
minfante14
Please give me advantages of placing revision clouds and tags on sheet views verses placing them in views placed on sheets.
My background is that we were to place them on sheet views.
Marvin L Infante
BIM Technician
Denver Colorado
Wed, Jan 20, 2016 at 9:36:24 AM | Revision Clouds and tags on Sheets or in Views?
We only place on sheets - never in views.
View placement requires the view annotation crop window, if on, to be large enough to accomodate the cloud.  Otherwise, its OK if you don't have annotation crop on and your cloud doesn't cross another view on the sheet.   << Really hard to manage
Sheet placement allows for multiple areas to be included in the same cloud.
Sheet placement requires you to be looking at the view on the sheet.  If you work on a view, while not on a sheet, you may never know how your cloud works with other views on that sheet.
Revision clouds - off on one sheet but not on other sheets - is this possible?
Fri, Mar 16, 2012 at 9:13:40 PM
Scheduling Revision Tags by Sheets
Mon, Oct 26, 2009 at 4:43:23 PM
revision clouds in multiple views?
Thu, Feb 25, 2010 at 8:57:42 AM
Revision Clouds
Tue, Dec 18, 2007 at 10:52:45 AM
Duplicate Revision Tags
Thu, Dec 4, 2008 at 4:45:57 PM
Page generation time: 0.6782
