73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall sweep with nested 2d detail on curved walls
Wed, Jan 20, 2016 at 3:33:08 AM | wall sweep with nested 2d detail on curved walls
bulcozor
hello all,
I'm having an issue w/ a wall sweep fam that has a nested 2d detail profile built into it.
The detail shows up well when a section cuts through the wall hosting the wall sweep, if the wall is straight
and perpendicular to the section cut.....however the 2d detail nested in the wall sweep does not show up when
it is hosted by a curved wall being cut by a section.....wall cut shows but not the detail in the wall sweep....it only
shows the profile perimeter, and blank on the inside, where the detail should show.
any ideas?....it seems to work fine on straight cut walls....
thanks!
Wed, Jan 20, 2016 at 7:13:31 AM | wall sweep with nested 2d detail on curved walls
Sorry but I don't believe this will ever work on a curve.  Revit seems to place any embedded details at a midpoint of the path and normal to that point.   Since this is a 2D detail, it will only show in a view normal to that location.   Almost no way for you to find that point.
Wed, Jan 20, 2016 at 6:12:09 PM | wall sweep with nested 2d detail on curved walls
bulcozor
yea....I was afraid you were going to say that Smile
I figured it had to do w/ the normal of the sweep/wall not being perfectly perpendicular to the section cut, but
I wanted to confirm that....make sure i wasnt doing something wrong....
wish there werent so many limitations when it comes to working w/ curved walls....there seem to be a number
of odities I run into when doing that.
anyway,
thanks for the reply!
How to do a vertical reveal in a sweep in a curved wall?
Thu, Oct 22, 2009 at 2:04:26 PM
Revit 2015, Curved Wall Sweep Model Surface Pattern Inconsistant
Tue, Apr 28, 2015 at 4:09:13 PM
section detail snaps on curved wall
Thu, Aug 16, 2007 at 3:14:56 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
2015 CURVED WALLS NOT DISPLAYING IN REVIT CORRECTLY
Fri, May 6, 2016 at 9:21:20 AM
Page generation time: 2.1311
