Forums >> Revit Building >> Technical Support >> Lineweight Problem
Hello!
Probably I am missing something very easy but, How can I make this Furniture to show below the wall so it doesn't cut the Lineweight of the Wall?
Sorry - no way to do this that I know of with model elements. Move the piece slightly off the wall.
Ok, Thanks. I just thought this was something basic that I just missed.
You could try using the linework tool under the modify tab. set it to invisible lines and then click the the line of milwork against the wall
This will work for some families but typically you don't use invisible lines, you would have to use the lineweight of the wall for the familly. However, it does not work with all furniture families, it changes all of the lines for some. Only those that have symbollic linework will work.
Still worth a try.
Yeah and usually you only want to use the linework tool in detail views but i figured might be worth trying is its only one location in the plan. I am thinking it is likely a problem within the family with the extrusions and sweeps or what not and thier visibility priorities.
Lineweight on Surface Patterns? |
Mon, Jun 15, 2009 at 11:54:53 AM
Lineweight in perspecives |
Wed, Sep 18, 2013 at 12:27:43 AM
Electrical Fixtures Lineweight |
Tue, Jul 21, 2015 at 12:39:01 PM
Lineweight Tool Overlap |
Thu, Aug 7, 2008 at 9:25:17 AM
Structural Footing Lineweight Issue |
Mon, Jun 18, 2018 at 12:05:58 PM
Members: | 2100632 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
