76 Users Online (75 Members):
Forums >> Revit Systems >> Technical Support >> Pipe Branch Takeoff/Gain
0 Posts No Rating |
Hi,
I am trying to create a pipe branch that adjusts the takeoff length based on the pipe it is connecting to. So far I can adjust this takeoff length in the family based on the size the branch is but not the pipe it connects to.
For example if I connect a 50mm pipe to a 100mm pipe I want the takeoff to be 125mm, the same as if I was connecting an 80mm pipe to a 100mm pipe, but it changes based on the size of the connecting pipe.
Any tips apprecited
Cheers
I would make a separate extrusion with an added parameter called take-off, and for each size, or type you can adjust that value so it will vary depending on the diameter. I hope it helps.
Struggling To Add A Branch Into Soil Pipe |
Thu, Sep 10, 2009 at 12:49:42 PM
Change pipe type of entire pipe run? |
Mon, Nov 1, 2010 at 9:40:44 AM
pipe tee size |
Thu, Jun 7, 2018 at 3:50:08 PM
Material Takeoff |
Mon, Apr 27, 2015 at 7:32:15 AM
Solar Gain and Windows |
Sat, Mar 10, 2007 at 8:12:43 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
