39 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Rooms Gross sf
Hi! Is there a way to get gross sf for each room? I need the area to be taken from the interior wall centerline and outer edge of exterior wall.
I know how to adjust the area/volume comps, but it seems the only options are to compute room areas from wall finish, wall center, and wall core, wall core center. I don't think any of those help in my case where i need the center of interiors and outer edge of exterior walls (?)
Are area plans my only option here?
Thanks!
Linda
When we need this, we turn off room bounding for the exterior walls and add our own room bounding line along the exterior.
That sounds like a great idea. I will try that. Thanks!
Gross volume of a building |
Wed, Jun 4, 2008 at 1:41:10 AM
Rentable vs Gross area, gross area in practice |
Tue, Mar 13, 2012 at 11:15:27 AM
Gross areas & Phasing |
Mon, Feb 23, 2015 at 9:14:01 AM
IFC export: Gross Area |
Fri, May 29, 2009 at 3:01:19 AM
first time using gross building area - whouldnt my shafts be deducted? |
Wed, Mar 26, 2014 at 1:39:28 PM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
