145 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Top control handle invisible (how to make it visible?)
Wed, Jan 13, 2016 at 5:08:18 PM | Top control handle invisible (how to make it visible?)
annateo301
Hi all,
I attempt to create 3d perspective floor plan view. I did the usual placing camera>orient to the floor plan that i wanted>turned on section box. All control handles for the section box are visible and I can drag/crop them. BUT, the top control handle remains invisible.
I tried extending my crop view beyond the section box, BUT the top handle is still no where to be found.
Does anyone know how to solve this?
Thu, Jan 14, 2016 at 4:25:24 AM | Top control handle invisible (how to make it visible?)
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
While in persepctive view, the perspective view angle often skews the section box planes such that they are completely out of view.
With the section box highlighted, go to a normal section view that shows the entire section box and you can then see the top and drag it down using the little arrow control.
Then return to your perspective.
The same can be done in plan views.
Thu, Jan 14, 2016 at 1:30:54 PM | Top control handle invisible (how to make it visible?)
annateo301
Genius! Thank you Beaucoupnice!
Thu, Jan 14, 2016 at 2:45:55 PM | Top control handle invisible (how to make it visible?)
annateo301
I also JUST noticed that you can select the Section box and then go to a section to adjust your crop!
Why isnt the Range Top, knobs and door handle not showing up in my Rendering
Thu, Dec 4, 2014 at 12:30:50 PM
Making The Invisible Visible
Thu, Aug 19, 2010 at 4:10:34 AM
Trying to get a handle on this half tone control
Wed, Jun 20, 2012 at 9:56:06 AM
Invisible lines not visible in Sheet view?
Wed, Dec 17, 2008 at 3:47:53 PM
Make objects visible but non-plottable?
Sat, Jul 2, 2005 at 10:29:52 PM
Page generation time: 1.6335
