88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2015 - Linked model annotation
Wed, Jan 13, 2016 at 9:11:42 AM | Revit 2015 - Linked model annotation
archie456
3 Stars: 1 Votes
Hi,
I've created an Architectural model which has suspended ceilings in it, and I want to link in the services model (created by someone else) to show the ceiling mounted services in the my ceiling plans.
This works fine, but all of the annotation which comes with the services model (say for smoke detectors or cameras etc) is quite large on the ceiling plan and I would like to reduce it.
I can change the view scale which does this, but it affects everything architectural too.
Is there any way I can only change the scale of the services model elements or make the annotation that comes with their families smaller?
Thanks.
Wed, Jan 13, 2016 at 9:13:44 AM | Revit 2015 - Linked model annotation
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No, the size is based in the families from the linked model.  They would need to change the size in their model.
Wed, Jan 13, 2016 at 9:25:32 AM | Revit 2015 - Linked model annotation
archie456
3 Stars: 1 Votes
And if they were to change the size in their model, then they would have to amend the annotation in each of their families - right?
That would be a lot of work...
Wed, Jan 13, 2016 at 9:30:52 AM | Revit 2015 - Linked model annotation
Is this really annotation or are they using symbols?  I suspect you are really talking about symbols.
Wed, Jan 13, 2016 at 9:45:58 AM | Revit 2015 - Linked model annotation
archie456
3 Stars: 1 Votes
Sorry, yes, their models contain symbols...
Does that change anything?
Wed, Jan 13, 2016 at 9:53:23 AM | Revit 2015 - Linked model annotation
Symbols and text do not change print size with view scale.  Only model elements change scale.  So if they have a model element with model text then it would scale ok but I suspected you were talking about symbols.
If they have model elements with embedded symbols, just turn off their symbols.
Architectural Linked model transparent annotation in 2013
Tue, Apr 16, 2013 at 1:49:24 PM
Section / Elevation annotation in Linked Revit Models
Fri, Jul 20, 2007 at 4:28:21 PM
How does one keep a linked model from becoming transparent
Thu, Nov 20, 2014 at 8:39:13 AM
2015: selecting elements in link
Tue, Nov 18, 2014 at 1:17:27 PM
12
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:23 PM
Page generation time: 3.1510
