Forums >> Revit Building >> Technical Support >> transfer project standards - line weights not transfering
0 Posts No Rating |
REVIT 2016
I am trying to transfer project standards for lineweights from an existing project to a new project. With both projects open and New project active,
I click transfer project standards then
check line weights, click ok. REVIT seems to think about it for a few seconds, but nothing happens. No warnings and nothing changes.
What obvious thing am I missing?
Thanks,
JK
![5 Stars: 2 Votes](/images/stars_5.gif) |
Hey Jill, you sure they didn't transfer? Did you verify under Manage>Additional Settings>Line Types?
0 Posts No Rating |
Trying to get line WEIGHT to transfer, not line type.
Yes, verified.
Sorry. And I suppose you checked Line Weights as well, and did not find the Line Weight you transfered.
And, you have less than 16 Line Weights listed, right? So, you've got room to add, right?
0 Posts No Rating |
Bartholomew
Yes, checked line weights, they did not transfer.
I am not trying to add additional line weights - trying to transfer them to match an existing project.
Meaning if the existing project has walls cut line at weight of 7, I want to transfer walls cut line at weight of 7 to the new project.
Edited on: Mon, Jan 11, 2016 at 6:43:48 PM
Oh, I see. You want to transfer "Object Style", not "Line Weight" to acheive what you're trying to achieve.
0 Posts No Rating |
Yep! That's it! I didn't know I wasn't asking the right question. Thanks!
TRANSFER PROJECT STANDARDS??? |
Thu, Jan 8, 2009 at 1:27:37 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Transfering project standards |
Thu, Feb 18, 2010 at 11:21:17 AM
Transfer Project Standards |
Tue, Sep 22, 2009 at 11:30:38 AM
Transfer Project Settings |
Fri, Apr 13, 2007 at 4:56:32 PM
Members: | 2016928 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
