78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Making Element, User and Material Keynotes look different
Fri, Jan 8, 2016 at 11:49:50 AM | Making Element, User and Material Keynotes look different
johnnyutah54
I'm fairly certian I know the answer to this question, but I'm trying here one last time. Does anyone know of a way to make keynote tags look different between each type, material, element and user? I just want them to show up differently on the screen to give users an idea of what they are changing. I haven't found a way yet.
Thanks.
Fri, Jan 8, 2016 at 1:00:03 PM | Making Element, User and Material Keynotes look different
3.5 Stars: 395 Votes
You could use different tags.   We use different colored tags but the user has to choose the proper tag when placing.
Fri, Jan 8, 2016 at 1:09:50 PM | Making Element, User and Material Keynotes look different
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
And once you get a few different tags placed in the view you can speed things up by using the 'create similar' tool to place more tags and not have to specify the tag type.
Fri, Jan 8, 2016 at 5:59:44 PM | Making Element, User and Material Keynotes look different
johnnyutah54
I've thought of using a different family, but that just seems like one more step for the user to take, and thus screw up. Any idea if the parameter is available to dynamo and a routine could be run to automatically change the type of the family based on the Key Source parameter?
How do you to tell the difference between Element, User and Material Keynotes?
Tue, Aug 17, 2010 at 4:48:31 PM
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Element Keynotes on Multi-Cat Schedules
Thu, Dec 28, 2023 at 10:07:15 AM
Material Keynote
Thu, Aug 10, 2017 at 6:36:44 AM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
Page generation time: 0.8054
