66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Structural Columns not cutting walls
Wed, Dec 23, 2015 at 5:40:22 PM | Structural Columns not cutting walls
bessig
I have a series of structural columns inside exterior walls. When I first place them, they cut the wall as expected. However, once I trim the top of the columns to a reference plane, the columns no longer cut the wall in plan. Any idea why this is happening? I've tried playing around with creating voids in the column family, but this doesn't work. I can't use the structural column to cut the wall.
Mon, Jan 4, 2016 at 6:45:52 AM | Structural Columns not cutting walls
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
First just check thats its not to do with view range or visibility.
Then take a look at this.
http://revitclinic.typepad.com/my_weblog/2011/04/structural-column-display-and-architectural-walls.html
Mon, Jan 4, 2016 at 4:13:26 PM | Structural Columns not cutting walls
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Is this a concrete column with a concrete wall and are both using the same 'material'. Also try using the 'join geometry' tool.
structural wall VS structural columns
Tue, Apr 26, 2016 at 3:49:40 PM
Strucutral Columns VS Walls in Call outs
Mon, Aug 16, 2010 at 8:17:06 AM
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:20 PM
Structural columns and most walls are black in camera view.
Thu, Mar 27, 2008 at 1:02:05 PM
linking structural file to architectural file
Tue, Nov 19, 2013 at 12:04:50 PM
Page generation time: 0.8253
