63 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Revit View Depth
Hello,
I am working on detailing some section & detail views, and ran into a problem. I need my Foundation plan, where these are all referenced to be cut 6'0" above 0'-0" in order to show all of the diffent elevation changes in the slab. The problem is that the details all need to be shwn lower around that 0'-0" elevation. Is there a way to modift the view depth of my sections & detail views, different from the Refferenced or Parent view? Thank you fro your time.
If you choose a floor plan instead of a detail plan when you create your callout, you can set your view range indepedent of the plan you called it out in.
Section view depth |
Tue, Jul 15, 2014 at 8:29:07 AM
Default View Depth |
Wed, Dec 7, 2011 at 11:38:25 AM
14
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN |
Fri, Aug 29, 2014 at 1:27:29 PM
2012 - Break Line on stairs below View Depth |
Mon, Oct 15, 2012 at 4:19:35 AM
depth of view |
Mon, Nov 21, 2005 at 9:46:00 AM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
