88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Floors appears to be floating in transparent green
Sun, Dec 13, 2015 at 7:31:49 PM | Floors appears to be floating in transparent green
MichaelInfante
Hi, I have a problem with the flooring appears to be floating in transparent green when viewed in 3D, but it is attached exactly on the floor level. I hope you could help me with this.
Thanks!
Michael
Mon, Dec 14, 2015 at 7:18:59 AM | Floors appears to be floating in transparent green
archigrafix
5 Stars: 4 Votes
What version of Revit do you use? Might be a problem with the driver of your graphic card.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Mon, Dec 14, 2015 at 7:45:28 AM | Floors appears to be floating in transparent green
More than your floors - also some walls.
Make sure your view is set to hidden line.  Check your material settings.
If you did not setup the model, then check your view settings and over-rides.
Wed, Dec 16, 2015 at 8:05:17 PM | Floors appears to be floating in transparent green
MichaelInfante
We are using Revit 2013, it might be with the video card, since I am using a laptop.
Used hidden line view instead.
Thanks for the advise!
Michael
Fri, Jan 29, 2016 at 12:05:33 AM | Floors appears to be floating in transparent green
MichaelInfante
Hi Everyone,
Sorry the New Thread hyperlink doesnt function in my account.
I need your help for the solid stair railing using sidings (please see attachment)
We are trying to cut it diagonally inorder to shape it together with the diagonal hand rail in which we couldnt figure it out.
Michael
Fri, Jan 29, 2016 at 7:50:07 AM | Floors appears to be floating in transparent green
DOn't use a railing.   Modify the wall and run the wall cap down that.
Floating Staircases
Fri, Oct 31, 2014 at 1:09:22 PM
Rendering glass in revit 2009
Mon, Aug 3, 2009 at 4:11:01 AM
Revit 9.1 ability to make transparent floors?
Thu, Nov 29, 2007 at 4:54:15 PM
Floors and walls being transparent in 3D view
Thu, Nov 12, 2020 at 2:52:52 PM
11
green transparent wall when in realistic mode
Wed, Sep 30, 2020 at 12:08:12 PM
Page generation time: 0.6313
