48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit export to DWG, lines and hatches in the same layer (after file upgreade)
Fri, Dec 11, 2015 at 8:18:37 AM | Revit export to DWG, lines and hatches in the same layer (after file upgreade)
Splendid2
Hi,
I open a file (made in revit 2015) in Revit 2016, so it upgreaded to higher version. but there is strange problem,
when I wanna export to dwg (default options) I Get drawing where  for example walls ang windows are in same layer and are
in SOLID HATCH!
There is no problem with files, which were started working in Revit 2016 (not upgreaded from older)
p.s. In Revit 2015 everything works perfect. I just wanna emphasis that all options are default in "Modify DWG/DXF Export Setup"
Fri, Dec 11, 2015 at 8:21:09 AM | Revit export to DWG, lines and hatches in the same layer (after file upgreade)
3.5 Stars: 395 Votes
You need to send this to Autodesk.
Export to DWG: distinguish Wall hatches from the inner and outher wall lines
Wed, Mar 1, 2006 at 8:34:41 AM
EXPOR LAYERS for WALL HATCHES are missing
Wed, Mar 1, 2006 at 8:30:58 AM
Export to DWF vs. DWG
Tue, Apr 24, 2012 at 3:52:31 PM
Keep .dwg Layers when exporting .rvt to .dwgPlease
Wed, Feb 24, 2016 at 9:27:59 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
Page generation time: 1.9518
