63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Roof Plan Issues- lower roof showing above upper roof
0 Posts No Rating |
Hey All,
I've got a roof plan thast I'm having issue with. There are to high roofs that are above a flat roof below, but in the plan, they are showing as below the flat roof. I am wondering why this is happening! Ipl ayed with the view range a little, but I really cannot think what would cause this. Any help would be appreciated! Attached is a capture of the roof plan, and a section coing through the right side of the roof N/S.
Thanks,
Garrett
Your question is not very clear.Look at your view's cut plane and view range settings. Also see if you have an underlay on.
0 Posts No Rating |
Yes, I should have proof read all that. anyway, I just figured out the problem. for some reason the plan was in Wireframe, when I changes it to hidden line, the roofs showed correctly.
Roof overlap |
Tue, Nov 9, 2010 at 8:25:43 AM
Linestyle Display Issue |
Tue, Jan 25, 2011 at 8:57:09 AM
Roof plan |
Fri, Sep 2, 2016 at 4:58:14 PM
Creating a Roof Plan in Revit |
Wed, Oct 3, 2007 at 8:51:58 AM
Roof Problem |
Sat, Mar 9, 2013 at 10:01:25 PM
13
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
