49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Schedule by Level?
7 Posts No Rating |
I'm trying to create an area schedule similar to the one that is attached. I was thinking I could create a new schedule for each level that breaks down the count, but I can't figure out how to give the units that aren't on a specific level a count of 0. Is there an easy way or workaround?Thanks in advance.
First, a Revit schedule will not look like that.
You can schedule both rooms or areas by level similar to what I have below. You could have a column for areas.
7 Posts No Rating |
I think I actually figured it out. Ended up creating 0 SF areas for each unit type on each floor and creating a calculated value for count using if(Area=0, 0, 1) and calculating totals which gave me an accurate count.
It's a little more complicated than that, but it works!
Some tasks one just have to imagine and improvise a solution. Glad that you made it to work. Nowadays one can use dynamo to manipulate that data.
Edited on: Tue, Dec 8, 2015 at 2:52:08 PM
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
sort door schedule by level without adding "level" column? |
Tue, Aug 15, 2017 at 11:27:04 AM
Schedule curtain panel by level? |
Fri, Sep 2, 2016 at 4:40:25 PM
Wall schedule - level field missing |
Fri, Mar 27, 2009 at 8:13:10 AM
Level Schedule |
Mon, Feb 11, 2013 at 1:30:12 PM
DOOR SCHEDULE LEVEL NAME |
Thu, Feb 1, 2018 at 6:53:18 AM
Members: | 2017540 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
